upgrade call manager from 6.0.1 to 6.1.1
Answered Question
Jan 12th, 2009
I am trying to upgrade the call manager from 6.0.1 to 6.1.1, I have downloaded the file from cisco which has part 1 ( ISO) and part 2 ( ISo File), I tried to combined the file by running "
COPY /D UCSInstall_UCOS_6.1.1.1000-11.sgn.iso_part1of2+UCSInstall_UCOS_6.1.1.1000-11.sgn.iso_part2of2 UCSInstall_UCOS_6.1.1.1000-11.sgn.iso" ... however the file I receive after combining two file is only 35k which is much much smaller than part 1 and part 2.... and when I tried to use ftp for the upgrade using this file... it just did nothing at all even it tried to download it from the ftp server.
is it normal to have the combined file which is much much smaller than the orginal ISO file?
Kind regards
Rachel
Correct Answer by Jaime Valencia about 8 years 1 week ago
use the right commands and you should get the right file:
COPY /B File1+File2 Dstfile
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 01/13/2009 - 04:31
java
