Richard Burts Tue, 01/13/2009 - 08:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rupesh
If you want Router 1 to get time from Router 2 and do not want Router 2 to get time from Router 1 then I would suggest that you configure on Router 1 the command ntp server and not use the ntp peer command.
Rick
