How to re-registrate a WAE at CM after changing the IP Address
joepena2012
Hello all,
we have trouble with "changing the WAE's IP Address after the device was registered to CM.
A registration of a device which was registrated with another IP Address is no more possible.
the following error occurs on the "sh CMS info" command:
Status = Pending(CM is busy, retry later)
pmccubbin
Level 5
Level 5
Hi Dieter,
Please let us know what version of software you are running.
(In version 4.1.1)
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v411/command/reference/execmds.html#wp1680452
On the WAE which you changed the IP address do this:
CMS deregister force
The cms deregister command removes the node from the WAAS network by deleting registration information and database tables.
cms enable
The cms enable global configuration command automatically registers the node in the database management tables and enables the CMS. Activate the node using the WAAS Central Manager GUI.
Then to verify:
show license
add license (if necessary)
show accelerator
Make sure to reconfigure the primary interface if needed.
Hope this helps point you in the right direction.
Best,
Paul
Hi Paul,
thanks for your response.
Yes we have 4.1.1 in use.
Version: oe612-4.1.1b.15
Currently the WAE is powered down.
I'll try to deregister the WAE, as soon as it is online again.
I'll let you know the outcome, as soon as possible
regards
Dieter
here the current status of the WAE
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
nbrwa222#sh cms info
Device registration information :
Device Id = 427442
Device registered as = WAAS Application Engine
Current WAAS Central Manager = 10.24.254.10
Registered with WAAS Central Manager = 10.24.254.10
Time of last config-sync = Fri Dec 19 10:17:46 2008
CMS services information :
Service cms_ce is running
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Hi Paul,
thanks for your help.
after the "deregister force" command we were able to register the WAE again.
Thanks for your help.
Dieter
I was just browsing and stumbled across thsi 3 year old post which had the exact information that I needed.
"CMS Deregister force"
Big thanks, wish I could vote your answer the correct answer.
