rohitrattan Tue, 01/13/2009 - 02:07
Hello Dear,
I believe you can check the command
"show interfaces counters errors"
I guess the last column of the output i.e. "Giants" is the one you should look at.
meanwhile i will dig into it..
Rohit
cisco_lite Tue, 01/13/2009 - 07:38
I have configured MTU 9000 on server and MTU 9216 on Cat6500 port interface.
And I can see the Giants counter going up on show interface counters errors. Are the jumbo frames being dropped ?
rohitrattan Tue, 01/13/2009 - 08:10
Hello Dear,
If the counters are going up i believe that the frames are being dropped, could be due to FCS error also. If you are having trouble configuring Jumbo Frames, i can provide some info that maybe useful.
Firstly Cat 6500 supports Jumbo Frames up to 9216 bytes but some line cards support Jumbo Frames only up to 8096 bytes due to some ASIC limitations. You can try and decrease the Frame size to 8096 on cat 6500 and a bit lower on the Server.
Secondly you have the following commands for configuring MTU and Jumbo Frames
(config)#System MTU 1500
(this applies to all interfaces)
but if you configure the following command
(config)#System MTU jumbo 9000
(this only applies to Gig ports and 10/100 ports use the system MTU setting)
also note that if you have configured Jumbo Frames that ingress on a Gig ports and egress on a 10/100 port those are dropped.
check this link for details:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
Rohit
cisco_lite Tue, 01/13/2009 - 08:35
Thanks.
In the below output, I can see giants but not CRC or any input output queue errors. Ingress and Egress both are gig ports set to the same mtu.
MTU 9216 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output 00:00:20, output hang never
Last clearing of "show interface" counters 02:48:16
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 13000 bits/sec, 2 packets/sec
12247 packets input, 19595925 bytes, 0 no buffer
Received 16 broadcasts (0 multicasts)
0 runts, 2995 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
15763 packets output, 26639834 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Server is set to 9000. Interface on Cat6500 is set to 9216. The line card used is not one of those included on the exception list in the given link.
rohitrattan Tue, 01/13/2009 - 08:54
Can you please provide the configuration you have done..i would like to see how you have configured it.
cisco_lite Tue, 01/13/2009 - 10:10
The interface configuration is as follows:
interface GigabitEthernet4/11
switchport
switchport access vlan 99
switchport mode access
mtu 9216
spanning-tree portfast
spanning-tree bpduguard enable
