ASDM Error
Answered Question
Jan 13th, 2009
Hi all,
when i try to connect with my ASA using ASDM application i got this error message:
"ASDM is unable to read the configuration from the ASA. Please check the configuration and your connection and then try again by clicking the refresh button".
Any suggestion?
ASDM Version 5.2
ASA Version 7.2(2)
Device Type ASA5520
Correct Answer by Pravin Phadte about 8 years 4 months ago
seems to have java problem
downgrade to older version.
jdk-6u7-windows-i586-p
Overall Rating: 5 (1 ratings)
Ivan Martinon Tue, 01/13/2009 - 08:17
  • Cisco Employee,
Can you do a show run from your ASA and at the very end of the ASA check the checksum value, does it have 32 characters?
Correct Answer
Pravin Phadte Wed, 01/14/2009 - 04:52
  • Silver, 250 points or more
evyciscouser Wed, 01/14/2009 - 05:16
I've downgraded to old version of Java and now everything works fine.
Thank you
Nicola
Pravin Phadte Tue, 02/24/2009 - 20:39
HI All,
For this now you can download the new ASDM which fixed the issuie.
asdm-61551.bin
Cisco Adaptive Security Device Manager for ASA 8.0(2), 8.0(3), 8.0(4), 8.1(1) and 8.1(2).
Hope this helps
evyciscouser Tue, 02/24/2009 - 23:52
If you can't downgrade your java environment you should update your ASA version and then your ASDM version.
Fot technical details contact CISCO support TAC.
