Port connection with Catalyst 3560G
Jan 13th, 2009
I have untagged traffic "green" and untagged traffic "red". My goal is: green-traffic flowing only in port 1 and 2; and red traffic flowing only in port 3 and 4. With the "old good" catalyst 3500 I used the switchport mode multi vlan, because there was untagged traffic in and untagged traffic out: no external VLAN was added.
How to get the same thing with Catalyst 3560G ?
garytayl Tue, 01/13/2009 - 13:25
  • Silver, 250 points or more
Not sure of all the details of your required config but one of the following scenarios should work for you:
1. Use both set of ports (1-2 and 3-4)as access ports (switchport mode access) and set the correspondent vlan (switchport access vlan x)for the red traffic. Use the same config for ports 3 and 4.
2. Use both set of ports as trunk ports (switchport mode trunk) and define the native vlan (untagged traffic) as vlan red and do the same for the other ports and define the native as green. However this will allow traffic from other vlans but tagged also, vlans going over this link can be restricted by the use of command: "switchport trunk allowed vlan"
