Warning message
Configure WISM controller Vlan Management
Jan 13th, 2009
Anyone can clarify me if is correct or not to confifure the WISM controller on a 6509 management in VLAN1 or is a must to put ( as Cisco Described : http://www.cisco.com/en/US/docs/wireless/technology/wism/technical/reference/appnote.html#wp40841 ) in VLAN 40 or any aother VLAN different by Vlan 1 ?
This question because now we found a broadcast storm passing through VLAN 1 and through the wirelles network
Thanks !
carenas123 Mon, 01/19/2009 - 13:50
  • Silver, 250 points or more
No, its not necessary it just gives the example.
abelleli71 Wed, 01/21/2009 - 01:09
The question was : can I use Vlan 1 or I have to change it to another "non default" VLAN ?
Stephen Rodriguez Mon, 01/26/2009 - 07:35
  • Purple, 4500 points or more
you an use whatever VLAN you wish. If all of your network is managed via VLAN 1, than that is fine. I know that some people recommend not using VLAN 1, but that is a personal call.
