Incoming calls now working + SIP
Answered Question
Jan 13th, 2009
I have a UC520 and it runs SIP to the ISP. Outgoing calls works fine but not incoming. The configuration is posted in a .txt file. Anyone that has any suggestions to what it could be?
Correct Answer by paolo bevilacqua about 8 years 5 months ago
Means mismatched codec, see the ITSP doesn't use G.711 that is cisco default. Just put "codec G.711" under the incoming voip DP.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 01/13/2009 - 04:50
  • Hall of Fame,
    Founding Member
Take "debug ccsip message" with "term mon", this will tell you the error. In most cases, mismatching numbers or codec.
Correct Answer
paolo bevilacqua Tue, 01/13/2009 - 05:16
  • Hall of Fame,
    Founding Member
