Jaime Valencia Tue, 01/13/2009 - 05:34
  • Cisco Employee,
  • Hall of Fame,
    2011
no, CUCM is not an IVR system.
you can use CUC, Unity, CUE, UCCX or UCCE for that purpose
java
if this helps, please rate
Mustafa Al Housami Tue, 01/13/2009 - 05:41
Hello Javalenc,
Usually i use tcl scripting or b-acd on CUCME to configure Autoattendant without using CUE.
I don't know if there anything similar to this feature in CUCM7.
I found that in CCM 4.2 and previous releases that there is a CRA application that can be installed on the same server that is running CCM 4.2 or previous releases.
However, on CUCM 7.0 which is based on linux OS, i don't know if it works the same way.
Kindly help
Best Regards.
Jaime Valencia Tue, 01/13/2009 - 05:48
  • Cisco Employee,
  • Hall of Fame,
    2011
i'm not sure if you still receive the cra disk on linux servers but that would require a separate server to install the app
java
Mustafa Al Housami Tue, 01/13/2009 - 06:28
well, is there any other way to configure auto attendant without using the CRS server??
Correct Answer
Jaime Valencia Tue, 01/13/2009 - 06:32
  • Cisco Employee,
  • Hall of Fame,
    2011
see 1st post
java
ABDOULHALIM Youssouf Wed, 07/13/2011 - 04:31
Hi javalenc,
I have implemented CUCMBE 7.1 on a linux system with unity.
Everythink works perfect.
But I need to configure auto attendant that can:
Answer a call
Play a user-configurable welcome prompt
Plays a main menu prompt that asks the caller to perform one of three actions:
Press 0 for the operator.
Press 1 to enter an extension number.
Press 2 to spell by name.
Please I need all the steps to through up to end. If possible the screen show of the steps.
