WLC failover
Answered Question
Jan 13th, 2009
I have 2 WLC, when i shut down the primary WLC, the 1231 AP didn't register to the backup WLC. All of the 1242 AP can register to the backup WLC. I wonder if the 1231 doesn't support the WLC failover.
Correct Answer by Stephen Rodriguez about 8 years 3 months ago
take a look under the Security tab, AP Policies. Make sure, if there is an SSC on the primary, that it also exists on the secondary.
Overall Rating: 4 (2 ratings)
Rob Huffman Tue, 01/13/2009 - 07:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Yang,
The 1231 should support failover just like the 1242's. Can you please check the second config listed below;
WLAN Controller Failover for Lightweight Access Points Configuration Example
Configure
1. Configure Mobility Groups for the WLCs
2. Assign Primary, Secondary, and Tertiary Controllers for the Lightweight AP
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008064a294.shtml
Hope this helps!
Rob
cscyangyu Tue, 01/13/2009 - 07:14
I configured the WLCs the same as this Doc, but after the primary WLC was shutdown, the 1231 APs
were shut down also . I checked the 1231 AP and 1242 AP . There is no difference between 1231 and 1242's configuration except the 1231 support b/g/n &a/n, 1241 only support a/g/n.
Correct Answer
Stephen Rodriguez Tue, 01/13/2009 - 09:05
  • Purple, 4500 points or more
cscyangyu Tue, 01/13/2009 - 09:10
Yes, you are right , The SSC is enabled on the Primary WLC, but not on the Backup WLC. Thank you very muchh , i will enable SSC on the backup WLC and test it at the weekend.
Thank your guys help .
ceracaza08 Sun, 01/29/2012 - 22:05
Can we do the same thing with WCL 4400 and 5500 series for failover? We have 1 existing 4400 WLC and we wanted to purchase another 1 for fail-over as well as backup. But right now, 4400 is EOL already. The only option is to have the 5500 WLC.
So if you do have previous set-up like this, so I would need your inputs.. Otherwise, same as usual, will gonna test to work this out.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
