AP not registering with WLC
Jan 13th, 2009
One of our Access-Point is continually failed to register on the controller.
Any idea what it could be or what can be done.
sschmidt Tue, 01/13/2009 - 08:58
Have you verified that option 43 is configured for the scope that these APs are supposed to be in? Are they additions to an existing network?
patel.nishit Tue, 01/13/2009 - 09:02
I have tried resetting the port but is is bouncing, and when I do a search on the WLC via mac-address it won't find it.
It worked fine for a while when we swapped to a different port and now it happening again.
Leo Laohoo Tue, 01/13/2009 - 21:46
Can you console into the AP that WON'T register/associate to the WLC? If so, do the following:
1. Make sure the AP can ping the WLC Management IP Address; and
2. Type the command: lwapp ap controller ip address
Does this help?
Stephen Rodriguez Thu, 01/15/2009 - 12:33
On the CLI of the controller, run the following debugs:
debug mac addr < mac address of the AP>
debug lwapp events enable
debug pm pki enable
This should help you narrow down why the AP is not joining the controller.
HTH,
Steve
