Giuseppe Larosa Tue, 01/13/2009 - 07:31
  • Hall of Fame,
    Founding Member
Hello Cisco_Lite,
be aware that you can change the mtu at different levels:
system mtu
at the L2 vlan level
using
conf t
vlan X
mtu
switch(config-vlan)#mtu ?
<576-18190> Value of VLAN Maximum Tranmission Unit
at the interface level:
int gi2/4
RT-RM-TLD066-RG-E-1(config-if)#mtu ?
<1500-9216> MTU size in bytes
I would change it at the vlan level for the servers applications to be sure it is correct on all required ports
However, if you prefere you can set it at the port level.
I would perform a shut/no shut cycle after configuration to be sure config is applied
Hope to help
Giuseppe
