EIGRP update being received on all but 1 router
nancyrawls
Made an update to an access list (advertising a new subnet out all interfaces) and all but 1 router received the update. The configs look to be identical so not sure why this one router is not updating it's routing table. When you do "sh ip eigrp traffic" the router in question is getting updates, hellos, etc.. When I do "sh ip route x.x.x.x." the response back is "subnet not in table".
Hello Nancy,
try to restart that specific EIGRP adjacency if it is on a dedicated link by shutting down and then up the link on the core side
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Nancy,
verify if that specific router has a distribute-list inbound filtering the new subnet (for example allowing only the old ones)
Hope to help
Giuseppe
no such luck but thanks anyhow.
Hello Nancy,
Hope to help
Giuseppe
That's what I was planning on doing - and sure enough - that fixed it! Thanks.
Rick Morris
Level 6
Level 6
Is it possible to post the config of the eigrp and acl/route-maps on the advertising router. and one working end point router and the router not receiving the route?
