Sniffer software for LMS 2.6
Answered Question
Jan 13th, 2009
I am trying to use sniffer trace between LMS server and a Router have communication problem with Ciscoworks.Which sniffer software is working easily and efficiently. any suggestion please.my LMS is on Sun Solaris 8.
Correct Answer by Joe Clarke about 8 years 1 month ago
wireshark -r file.jet
There's nothing special about the .jet file.
Snoop works well:
# snoop -o /tmp/outfile -s 1518 tcp port 23
However, LMS comes with a sniffer built in. You can find it in Device Center > Tools > Packet Capture.
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Tue, 01/13/2009 - 10:07
Snoop works well:
eliaspaulos Tue, 01/13/2009 - 14:09
thanks J. actually i did get the sniffer file from device center try to open on Wireshark. wire shark unable to open .jet file. could you help me how i can open the .jet file on wireshark to analyze?
Correct Answer
Joe Clarke Tue, 01/13/2009 - 14:23
