Certain Websites timeout when trying to access
Jan 13th, 2009
Can anyone help with this issue, since a couple of days ago we are having trouble accessing certain websites.
When attempting to access the site the PC will hang and eventually display "Request Timeout". On other pages certain parts of the site will not display.
We have an ASA 5510 Firewall and a 1841 Router which is maintained by our ISP.
One example is www.matrox.com (, I cannot ping from the Inside or Outside Interface of the ASA nor PC's on our network.
I have contacted our ISP who say they can ping this address from their Router.
Below is an example of the end of a trace route, firstly from network-tools.com (and anywhere else I've tried)
9 55 69 60 -
10 55 53 71 -
11 72 61 86 www.matrox.com
and from our Firewall
12 137 ms 137 ms 135 ms
13 131 ms 132 ms 134 ms
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
As you can see it doesn't make the last hop.
Does anyone have an idea how to resolve this or how to debug this issue.
shaw.chris Tue, 01/13/2009 - 13:00
To add to the confusion:
All our PC are NAT'd to go out as the ASA interface address x.x.231.82,
On the ASA I've just configured an individual PC to NAT as a different address x.x.231.84 and I can access and ping the problematic websites from this PC.
Ivan Martinon Tue, 01/13/2009 - 13:43
Hi Chris,
If you do not have ICMP inspection enabled on your ASA ping will never reply back from your internal network, that's one thing to check. Go to your ASA and from it ping the ip address for this Matrox site and see if you got an answer.
As for the webpages timing up, go ahead and check with the "show run policy-map" if the inspect http is enabled, if it is try to disable it and test again your webpage connections.
It would also be useful to check any logs from the asa to see if those packets (web traffic) is being dropped by any reason.
shaw.chris Tue, 01/13/2009 - 14:27
I do have ICMP inspection enabled, so I do receive replies. Inspect http is not enabled and nothing shows up in the logs at all when I try and access these sites. Most websites are fine
As I mentioned if I change the outgoing address to a different IP from our external IP range it works OK
Does anyone have any idea how to resolve this?
Thanks, Chris
Ivan Martinon Tue, 01/13/2009 - 14:30
OK, thanks for clearing up, so what you are stating is that if you use a different address for the nat that those users behind are using all works fine? This my friend has to do with how that ip address is assigned or router by your ISP.
