Cisco 6509 High CPU Load
Roberto Salazar Tue, 01/13/2009 - 12:44
  • Gold, 750 points or more
under show proc cpu detailed under "ios-base" and "iprouting.iosproc" what do you see? there should be other process that will tell you which process in particular contributes to high utilization to ios-base and iprouting. Also, check your log, see if there are any logs that might be related to high cpu.
