Multilink PPP over Ethernet
Jan 13th, 2009
Hi to all!
It is possible to run MLPPP over Ethernet dot1q subinterfaces?
I fact, 2 PPPoE sessions on Multilink.
On the customer site I have a 1841 with 2 ADSL WICs.
This 2 PVC's are terminated on the 7600 on 2 VLANs..
Thanks and regards,
drolemc Tue, 01/20/2009 - 14:29
It is not possible to run MLPPP over Ethernet dot1q subinterfaces.
PPPoE does not support multilink PPP.
thomas.feichter Wed, 01/21/2009 - 06:37
thanks for post.
What are the best solution to achieve a load-balancing? I see only CEF load-balancing as solution...
Any other idea?
Thanks and regards,
Pravin Phadte Thu, 01/22/2009 - 06:07
If you are looking to loadbalnce the wan links its MLPPP.
In LAN you can use etherchannel.
