Multilink (MPLS) intfc taking LOTS of input errors while T1s clean..?
Jan 13th, 2009
I have a Multilink interface that is taking a bunch of input errors (accumulating rapidly) while the underlying T1s are running clean. Don't recall seeing this before, and despite my efforts searching can't seem to find anything relevant.
interface Multilink123
bandwidth 3088
ip address x.x.x.x 255.255.255.252
no peer neighbor-route
ppp chap hostname xxx
ppp multilink
ppp multilink fragment disable
ppp multilink group 123
service-policy output voice
interface Serial0/0/0:0
no ip address
encapsulation ppp
ppp chap hostname xxxxx
ppp multilink
interface Serial0/0/1:0
no ip address
encapsulation ppp
ppp multilink
#sh int multi 123 | incl errors
2991771 input errors, 0 CRC, 2991771 frame, 0 overrun, 0 ignored, 0 abort
[ errors actively increasing.. ]
2992394 input errors, 0 CRC, 2992394 frame, 0 overrun, 0 ignored, 0 abort
[ underlying t1s are clean! ]
#sh int ser 0/0/0:0 | incl errors
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
#sh int ser 0/0/1:0 | incl errors
Has anyone seen this before?
bagvanliju Wed, 01/14/2009 - 01:08
input errors are combination of all errors,If 2992394 input errors, 0 CRC, 2992394 frame,
try to reconfigure your Multilink,check individual T1's are error free by checking the loop.
ujil
Giuseppe Larosa Thu, 01/15/2009 - 12:54
  • Hall of Fame,
    Founding Member
Hello Mike,
try to use
show ppp multilink to see if there are error counters also here.
You have input errors all of them of type Frame (meaning CRC errors or a non integer number of octets)
Number of packets received incorrectly having a CRC error and a noninteger number of octets. On a serial line, this is usually the result of noise or other transmission problems.
see
http://www.cisco.com/en/US/docs/ios/12_0/interface/command/reference/irshowin.html#wp1020497
but the multilink is not a physical serial interface so
sh ppp multilink may help
Hope to help
Giuseppe
msuter Thu, 01/15/2009 - 13:53
sh ppp multilink doesn't appear to show anything too serious:
RTR#show ppp multilink
Multilink123, bundle name is host1056
Endpoint discriminator is host1056
Bundle up for 21:46:17, total bandwidth 3072, load 12/255
Receive buffer limit 24000 bytes, frag timeout 1000 ms
0/0 fragments/bytes in reassembly list
6 lost fragments, 79602 reordered
0/0 discarded fragments/bytes, 0 lost received
0x15DA55 received sequence, 0x2B8600 sent sequence
Member links: 2 active, 2 inactive (max not set, min not set)
Se0/0/1:0, since 21:46:17
Se0/0/0:0, since 21:31:24
Se0/1/0:0 (inactive)
Se0/1/1:0 (inactive)
No inactive multilink interfaces
MTU is 1500
Thanks!
Giuseppe Larosa Thu, 01/15/2009 - 14:21
  • Hall of Fame,
    Founding Member
Hello Mike,
I see something I don't like:
what if you remove ppp multilink on these unused interfaces ?
another note: I always used low numbers for multilink what if you configure again a ppp bundle but with a low index like 5 ?
(all right this is just a note)
Hope to help
Giuseppe
