CUPS over VPN (PPTP)
Jan 13th, 2009
Versions
UCM 6.1.2.1002-1
Presence 7.0.2.10000-36
CUPS client 7.0(1.13056)
Windows 2003 VPN (PPTP/GRE)
The CUPS client works wonderfully on LAN/WAN, but when using VPN, it logs in and shows status, but LOGON SERVER and LDAP SERVER show unavailable.
When try to start a chat, says 'An Instant Message could not be started because the network appears to be disconnected.'
Interestingly, Presence phone (UPC[username]) and TFTP are green.
Routing works and more, so, the LDAP server is in the same L2 network as the VPN server's interface.
I read through several posts regarding this issue, including:
- validate profile is set to Cisco SIP Proxy TCP Listener (this was under App --> CUPS --> Settings for v7)
- validating our FW does not do SIP inspection (though moot, since our FW isn't the terminating point for the VPN tunnel, so it's all encapsulated through the tunnel)
- acknowledge the known bug/caveat (CSCsf26033) in the CUPSr7 release notes which says to use TCP for the profile.
I even used Wireshark to validate the frames were TCP and the servers are talking and they appear to be!?
Yet, RED for both those servers.
I'm stuck and could use some suggestions.
(Love this site, by the way)
Thanks, all.
Logan
htluo Tue, 01/13/2009 - 16:59
The easiest way to troubleshoot network-suspected issue is to do a packet capture on CUPS server. Here are the steps:
1) SSH to CUPS
2) Type command below
utils network capture file cups count 100000 size all host all 192.168.2.100
substitute 192.168.2.100 with the IP address of the CUPC client
3) Type command below to transfer the file to a SFTP server. If you don't have a SFTP server, download one from www.freeftpd.com.
file get activelog platform/cli/cups.cap
4)Upload the file here and let me know the IP of the CUPS and CUPC.
Thanks!
Michael
My blog:
http://htluo.blogspot.com/
My book:
http://www.lulu.com/content/5552336
loganseth Wed, 01/14/2009 - 06:28
Wow, thanks, Michael, for the response and information. This is great stuff. I had no idea Cisco made the sniffer functionality available on UCM. Nice!
Attached is the file, per your request.
CUPS is 192.168.202.4 and CUPC is 172.16.103.3 (VPN'd in).
The process I ran:
1. VPNd in
2. SSHd to CUPS
3. Started sniffer
4. Launched CUPC
5. After it loaded, I saw status, then verified the same problem persisted (logon and ldap server unavailable (red)) via server health.
6. CTLR+C on CUPS
Then xferred file over and am uploading it.
I appreciate the assistance and education!
Logan
Johann Aicher Wed, 01/14/2009 - 07:05
if you span/mirror the switch port on which CUPS is connected to to your PC and run Sniffer or Wireshark you get the same file even much faster...
It is even better to capture the frames on the internal interface of your vpn device because CUPC is also communicating with your DNS server(s) and your LDAP server(s). This communication is not shown on the CUPS because it newer reaches it...
But you can't see into the conversation which is protected by TLS. So you are not able to get information about the login process from CUPC to CUPS.
Question for htluo: Is there a way do disable TLS between CUPS and CUPC for trouble shooting or get a capture behind the TLS process on CUPS ?
loganseth Wed, 01/14/2009 - 07:23
indeed.
alternatively you can capture from the client (wireshark locally) which I did before opening this discussion. i'm baffled because L2/3 connectivity is solid; so IMHO this must be an application issue - something restricting it.
what about this theory:
Per the r7 CUPS release notes, under Table5, SW REQ for CUPC on M$, it has 'Cisco VPN Client SW, r5 of later' for VPN requirement.
http://www.cisco.com/en/US/docs/voice_ip_comm/cupc/7_0/english/release/notes/ol15710.html#wp125082
Perhaps the r7 CUPC client 'looks' for the VPN client and doesn't let you connect without it?
Again, we're using the Windows VPN client.
Johann Aicher Wed, 01/14/2009 - 07:32
You can also enable detail logging in CUPC - help and look into the c:\documents and settings\user name\local settings\apps\cisco\Unified Personal Communicator\logs\UnifiedClientLog4CXX.txt.x
and respilog.txt
Don't forget to disable detail logging after that.
loganseth Wed, 01/14/2009 - 09:14
I enabled detailed logging and this looks interesting:
2009-01-14 11:13:18,214 [0x00000f0c] DEBUG LCDirectory - LDAPDirectoryImpl::SearchThread:RequestQueue has [20] pending requests
2009-01-14 11:13:18,214 [0x00000f0c] DEBUG LCConnection - LDAP_DB reportResult(DISCONNECTED): reason=UNREACHABLE, functionality=NONE
2009-01-14 11:13:18,214 [0x00000f0c] DEBUG LCConnection - LDAP_DB setReason(): [SUSPENDED] --> [UNREACHABLE]
2009-01-14 11:13:18,214 [0x00000f0c] DEBUG LCConnection - $$$***** LDAP_DB Server 192.168.1.14, State was IDLE, ServerAdapter 0x70008
2009-01-14 11:13:18,214 [0x00000f0c] DEBUG LCConnection - LDAP_DB reportResult(): unexpected result (DISCONNECTED) for state IDLE
2009-01-14 11:13:21,214 [0x00000f0c] DEBUG LCDirectory - LDAPDirectoryImpl::SearchThread:RequestQueue has [20] pending requests
2009-01-14 11:13:21,214 [0x00000f0c] DEBUG LCConnection - LDAP_DB reportResult(DISCONNECTED): reason=UNREACHABLE, functionality=NONE
But the LDAP server does appear reachable (via ICMP or http or telnet)...any thoughts on this?
Thank you, all, again for your help.
htluo Wed, 01/14/2009 - 10:05
From sniffer capture, presence part worked fine.
Could you do the following?
1) On CUPC > Help, enable detailed logging.
2) Exit CUPC (make sure it's not running in the system stray if you're using CUPC 7.x)
3) Delete all old logs in "%USERPROFILE%\Local Settings\Application Data\Cisco\Unified Personal Communicator\Logs"
4) Run sniffer capture on CUPC client and start capture.
5) Launch CUPC and wait for the problem.
6) Stop sniffer capture.
7) On CUPC > Help > Create problem report
Attached sniffer capture and problem report here. We should be able to tell. :)
loganseth Wed, 01/14/2009 - 10:23
Ok, followed the steps and attached are the (a)logs, (b) CUPC wireshark capture, and I am looking for the zipped problem report now...not sure where it saves it...it said it created the problem report successfully, but didn't show up in the 'Cisco' directory under Local Settings...
htluo Wed, 01/14/2009 - 10:34
the problem report was created on your desktop by default. I'll take a look at the files you upload.
htluo Wed, 01/14/2009 - 11:20
It looks like we do have some network issue here.
In sniffer capture, things are not right after packet 264 (LDAP unbind).
After packet 264, we should be seeing a "tcp three-way handshake" - SYN, SYN/ACK, ACK.
After the handshake, we should see CUPC initiate another LDAP bindRequest.
In your capture, we only see FIN and FIN/ACK.
You'll need LDAP server packet capture to further investigate. But at this point, we're pretty sure it's network related.
Michael
loganseth Wed, 01/14/2009 - 11:45
Nice! yes, I see the unbind now in 264 and the FIN/ACK in 266. I'll try to generate a capture on the LDAP server next.
Attached is the CUPC (from the desktop!)
loganseth Wed, 01/14/2009 - 12:07
another lead perhaps?
I captured the same data (on the CUPC client) while connected to the LAN (when everything is working) and stripped out the same requests to the same server (.1.14).
the observation here is this:
1. bindRequest(1) completes at frame 7
2. unbindRequest(2) starts at frame 8
3. we observe FIN/ACK, etc and then
4. DNS requests for CUPS at frame 13
5. These carry 10 frames until frame 22
6. Then in Frame23, we see the new SYN to setup bindRequest(3)
In the 'non-working' (while I am VPNd in) we observe the same steps 1-5, but then
6. a DNS request not in the working capture appears in frame 21.
7. all frames 21 - 26 are not present in the working capture
And then there is the missing Bind(3) that you are referring to.
So my hunting trail right now is trying to isolate why those extra DNS requests are made. Why does the client need to make those while VPN'd in but not while connected to the LAN?
Wild!
htluo Wed, 01/14/2009 - 14:20
Those "extra" DNS query were for LDAP:
Packet #21
labattsapdc.labattsa.labattfood.com
Packet # 23
_ldap._tcp.Default-First-Site-Name._sites.dc._msdcs.labattsa.labattfood.com"
When the PC was in LAN, I think those already got populated into DNS cache during DHCP or logon process. Hence the LAN PC didn't have to query it again.
loganseth Wed, 01/14/2009 - 14:25
ah, gotcha...that would make sense...you are still thinking 'network related' though? the same FIN/ACK combination exist in both trace files, it's just the 3rd instance (and new 3-way handshake) is missing...as if 'something failed' like a dependency, so #3 never kicked off...i can certainly communicate with the LDAP servers, so why isn't it 'starting' the 3rd BIND?
ARGH!
Hey, again, I really appreciate the help.
htluo Wed, 01/14/2009 - 14:35
At this point, I think you'd better open a TAC case. You'll need the TAC engineer engage CUPC dev team to find out the workflow.
Johann Aicher Thu, 01/15/2009 - 01:58
I'm also wondering about the DNS lookups for:
I also see this behaviour in my lab and there is no information in the Cisco docu about correct DNS entries for CUPS / CUPC!
If you use "ipconfig /flushdns" then you get an empty DNS cache. This is allways good before capture packtes.
We had the same error with CUPC over Checkpoint VPN! Since I opened all ports without Firewalling to CUPS it runs and all are happy!
loganseth Thu, 01/15/2009 - 06:22
Nice recommendation on the DNS flush...yea, man, what is that call!?
From several posts it sounds like FW tweaking is necessary, but I've struggled with that solution since our endpoint is a Windows device that sits behind a FW, so the VPN client traffic is tunneled through the FW - so how would the FW inspect it?
ARGH!
In all sincerity, I really appreciate this conversation and everyone's assistance. It is refreshing to be in the company of other I.T. folks who are interested in solving problems and supportive. I look forward to 'paying it forward.'
Johann Aicher Thu, 01/15/2009 - 06:48
Have you ever tried DRTCP021.exe to reduce the MTU size of your Test-PCs eth interface - for example to 1400 or 1300 Bytes ?
This has resolved some of the GRE / PPTP / IPSec VPN / DSL issues I had before.
It depends on your VPN tunnel device how it handles larger packets than it can transport ( cut or devide or drop ).
loganseth Thu, 01/15/2009 - 07:15
woah...DrTcp? Man, that's a new one to me...I'm testing on WWAN card from Verizon, so I will try and run it to reduce the MTU size on that interface...
Do you have any more information to the theory behind this change? What is the default MTU size? What adjust?
Johann Aicher Thu, 01/15/2009 - 07:25
The default MTU of Eternet is 1500. So if you have any tunnel to pass the tunnel devices has to handle that to big packets. Because any tunnel has one or more headers ( GRE / PPTP / IPSec / SSL .. ), the packets have to be handled correct. One bad thing is when a device cuts the packet and drops the rest of it. It depends also on the IP protocol ( UDP or TCP ) and the implementation of the IP-stack on the machines.
I had allways a good result with an MTU of 1400 bytes.
loganseth Thu, 01/15/2009 - 07:37
Nice!
Ok, I just tried it, left all the 'general settings' alone, changed the 'Adapter Settings' for the WWAN interface to 1300 MTU (that was the drtcp default), rebooted, re-connected and received the same result.
Do you think I missed a step or should I have adjusted anything else in the drtcp app?
Johann Aicher Thu, 01/15/2009 - 07:52
Sorry, I've been looking into your "ldap_bind_working_2.cap". On frame 23 in the options field your client uses only 1260 Bytes. So this cannont be the problem.
You can take a capture at the internal side of your VPN tunnel device and compare the results.
Cisco says that they are having problems with NAT inside the communication between CUPS and CUPC.
Hello.  I was just following through this link, and have a similar problem/resolution that might shed some light on these problems.
I was working with a customer with CUPS 7.0.5, CUPC 7.0.2.  Within they're network, CUPC will connect and work fine.  Once we vpn we can authenticate, but the client would show conneted(Limited) and the Presence server health would show connecting/disconnecting/pending etc.
I did a packet capture on my PC with CUPC loaded, not on the VPN connection, but on the interface that was providing the transport for the VPN connection, IE the LAN Interface, not the PPTP interface.
What showed in capture was several DNS lookups to my LAN dns server, rather than the PPTP provided dns server.  The lookups were for _sip._udp.cups.domain.name, and _sip.tcp.cups.domain.name, and _stun.udp.domain.name.
My local dns was responding with no such name, since my local isp would not have the cups server domain name, and this was is a private ip address, not a public address.
This points to a problem with the CUPC client requesting the DNS information from the LAN, not the PPTP interface.  All ping requests/web requests for the cups.domain.name worke fine, and can resolve the cups address from the name as expected.
As a test, I setup a temporary dns server, added the remote customers domain as a zone, with the private ip address/hostname for the cups server, and used this for my LAN interfaces DNS server.  Now when vpn'd in, the CUPC client will connect and work just fine.
I don't think this is a good solution in any means, but it does show that the CUPC client is the issue.
Any Tips/Tricks that the Author of "Deploying Cisco Unified Presence" can add?  I got a well used copy that I've gone through in troubleshooting, and know the writter lurks in these forums....
