limit bandwidth per SSID on aironet 1200 series
Jan 13th, 2009
i want to create 2 ssids on and limit bandwidth to 10 percent using a policy map on a 1240 or 1230 series ap. i tried creating a class and using the match vlan then under the policy configuring it with the bandwidth percent command, then applying it to the sub interface on that radio for that vlan. it takes the command but it doesn't show up in the running con fig and it doesn't seem to be working. are these commands supported? is it possible to limit bandwidth right over the air on a particular vlan using this access points?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
