SRST time recovery
Jan 13th, 2009
Hello Folks We have a customer who wants to reduce the time that the ip phones takes to recover from the srst mode to the normal bahavior in call manager. We have the default timer but we wonder if there could be a timer that coud be modified in order to reduce it.
Thanks for your help.
Nicholas Matthews Tue, 01/13/2009 - 17:23
I think this is the enterprise parameter you're looking for:
Connection Monitor Duration: This parameter specifies the a common link qualifying time period for all the devices using a specific SRST reference.
This is a required field.
Default: 120
Minimum: 0
Maximum: 2592000
: Restart all services for the parameter change to take effect.
In later versions of CUCM this is also a Device Pool configuration.
hth,
nick
