ring back timer
Jan 13th, 2009
Hello Guys.
We are experiencing troubles with incoming calls that normally takes 8 seconds to return the ring back to the person that is calling from the pstn. We discussed with the telco guys about this issue and they said that this delay is because of the router, which takes to long to answer wit the ring back. Do you have any idea that something that could solve this issue in call manager or router?
Thanks.
Nicholas Matthews Tue, 01/13/2009 - 17:29
  • Red, 2250 points or more
What's the call flow? Does (and which part) goes over a WAN?
-nick
Jaime Valencia Tue, 01/13/2009 - 19:28
  • Cisco Employee,
  • Hall of Fame,
    2011
GW? H323? MGCP?
CUCM? CME? versions?
had discarded overlapping DNs?
not enough info to provide any help
java
Gilberto Marcos Thu, 01/15/2009 - 12:29
Hello.
The call comes as follow:
pstn--H323gateway--call manager 6.1(1)--Ipphone.
Telco guys said that when the router received the last digits that the pstn user dialed, it takes 8 seconds to call to be completed.
This guys are telling that they can not modify anythig at their side, because the router is the one which presents this delay.
Thanks.
Gilberto Marcos Thu, 01/15/2009 - 12:28
Hi Nick.
Thanks.
Nicholas Matthews Thu, 01/15/2009 - 12:38
A couple of things you can try:
If you have a PRI ( your diagram does not indicate what type of PSTN interface you have )
try this:
Serial0/0/0:23
no isdn overlap-receiving
On CUCM:
MTP required
Enable outbound fast-start
hth,
nick
Gilberto Marcos Mon, 01/19/2009 - 13:17
sorry We are using e1 with R2 as signaling.
I don't now if these commands can help
Nicholas Matthews Mon, 01/19/2009 - 13:48
You can still use those commands, as they are H323 commands.
However, E1 R2 has the tendency to be a very slow protocol. To troubleshoot this problem you would want to pull gateway traces as well as CUCM traces to see what's going on.
hth,
nick
