VPN issue
Jan 13th, 2009
Hello all, I am having a problem getting a vpn to come up. Normally when i get this problem i just turn on all crypto debugging and any piece of logging information points me in the right direction to fixing the VPN. For some reason i am getting no logging information what so ever except the router logs just saying "create signature" every few minutes.
It is a cisco 1812 running iso 12.4. Strange thing is i am not seeing any logging information whatsoever from the peer router or the host router. I have tried different networks (even just a few test ones that would not conflict with out subnet) and have also tried to connecting to different cisco 1812s and a concentrator 3000. no logging info AT ALL. driving me crazy!
any ideas would be awesome. thanks.
muca Tue, 01/13/2009 - 17:56
Have you enabled terminal monitor?
router#terminal monitor
nathan.carroll@... Tue, 01/13/2009 - 18:07
Ok i have turned on terminal monitor. Should this give me extra logging?
last few lines of logging have showed
generate publick/private keypair
No peer struct to ger peer dessciption
Does this extra information help ?
Richard Burts Tue, 01/13/2009 - 18:43
The message that says:
is an indicator that IPSec VPN is not working. Perhaps it would help us find the problem if you would post the config.
