Ping in IOS
What is the IOS PING command for a DOS style below?
Pinging with 32 bytes of data:
Reply from bytes=32 time<1ms TTL=253
m.sir Wed, 01/14/2009 - 00:26
Its no suprise its command
Offers some more option (like change source, specify packet lenght, packet numbers etc..)
try ? to see options
Pravin Phadte Wed, 01/14/2009 - 04:39
You will not get the ping as specifed in the windows dos commnad.
You need to use "?"
Ping ?
will provide you with option.
simple example is in win we have ping -t
on cisco it would be
ping rep 100 or 100000
Hope this helps
Well, Found the answer. Below is the example.
Protocol [ip]:
Target IP address:
Repeat count [5]: 100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: Serial0/0
Type of service [0]: 2
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]: Verbose
Loose, Strict, Record, Timestamp, Verbose[V]:
Sweep range of sizes [n]:
Sending 100, 100-byte ICMP Echos to, timeout is 2 seconds:
Packet sent with a source address of
Reply to request 0 (12 ms)
Reply to request 1 (8 ms)
Reply to request 2 (12 ms)
Reply to request 3 (8 ms)
Reply to request 4 (12 ms)
Reply to request 5 (8 ms)
Reply to request 6 (8 ms)
Reply to request 7 (12 ms)
Reply to request 8 (8 ms)
Reply to request 9 (8 ms)
Reply to request 10 (8 ms)
Reply to request 11 (8 ms)
Reply to request 12 (12 ms)
ahmedchohan Wed, 01/14/2009 - 23:01
Didn't get you, how is this output different to the normal ping in IOS ?
