ASA 5510 connectivity issues to 3550 Catalyst
Jan 13th, 2009
I am having a nightmare trying to connect my shiny new ASA 5510 to an old Cat 3550 switch. The ASA port shows up/up but receives no packets at all. As soon as I put the cable back in to the old PIX515E it works straight away, making me believe this is a bug between the 5510 and the 3550. I have tried countless combinations of speed/duplex, and I've upgraded both the switch software and ASA software to latest levels. I have even tried a different ASA. The only way I can get the link between the ASA and the switch to come up is to place a "Linksys residential cable router with 4-port switch" in between!!! Clearly the 5510 and 3550 do not like negotiating a link for whatever reason.
Any help will be massively appreciated.
Thanks, Mark
handsy Wed, 01/14/2009 - 02:42
Thanks for your reply. As mentioned, I have tried countless combinations of speed/duplex and I am definitely not using x-over cable :(
What software level is your ASA/3550 on? ...and are your ASAs the 5510 variety?
handsy Wed, 01/14/2009 - 02:52
I can't do full config for switch as I don't own that end, but I was given the interface config:
interface FastEthernet0/47
switchport access vlan 14
switchport mode access
speed 100
duplex full
no snmp trap link-status
spanning-tree portfast
..and the ASA port config is as follows:
interface Ethernet0/3
description Corporate Network Link
speed 100
duplex full
nameif corporate
security-level 5
ip address x.x.x.x 255.255.255.192
The ASA is a 5510 running 7.2(4) and the switch is a WS-C3550-48-SMI running 12.2(44)SE3.
handsy Wed, 01/14/2009 - 04:40
Yeah did that too, and the ASA end comes up saying "Half/100" !!
Cable is perfectly fine to the PIX515E so it's not a cable problem.
Thanks for your help anyway.
