01-13-2009 11:30 PM - edited 03-15-2019 03:30 PM
how to register mobile commnicaotr on symbian,nokia E61, to callmanager 7? i have tried to check several thing, document guide but until now no resouce to find, do anyone had a chance to use this before, how to config?
Solved! Go to Solution.
01-14-2009 04:21 AM
Cisco Unified Mobility that is built into UCM consists of Mobile Connect (aka Single Number Reach) and Mobile Voice Access (aka DISA).
The Nokia E61 can also register as a SCCP phone when connected on a WiFi network if you purchase the license from Nokia.
Mobile Communicator requires a CUMA server.
01-14-2009 12:16 AM
In order to Install and use CUMC (Mobile Communicator) you will need to setup a CUMA (Mobile Advantage) server
http://www.cisco.com/en/US/products/ps7271/products_user_guide_list.html
01-14-2009 12:47 AM
so what 's about mobility that CM6-7 support , did not mobile communicator also? cause i seen device in ipphone,
in case if we need to buy mobility advantage , do we have to buy software and license also.
anyway thank you in advance
01-14-2009 04:21 AM
