Initiation VPN tunnel from the static to dynamic side
Answered Question
Jan 13th, 2009
In case of site to site VPN between static IP (ASA) and dynamic IP (Linksys AG241), would it be possible to initiate VPN tunnel from the static side? How can I configure it? Could you please advice?
Thank you very much,
Nitass
Correct Answer by sachintyagi about 8 years 1 month ago
Nitass, I am quite sure that you cannot initiate a session with from ASA, that is from VPN server side.
Overall Rating: 5 (1 ratings)
sachintyagi Wed, 01/14/2009 - 01:23
Nitass,
ASA would not support dynamic VPN like DMVPN. If your Linksys device supports, you can configure EZVPN between ASA and the Linksys device. This way you can have a static IP address on the ASA and a dynamic ip addr on Linksys device.
nitass Wed, 01/14/2009 - 01:30
Hi Sachin,
Thanks for reply. Anyway, can I initiate the VPN tunnel from the Linksys (dynamic IP) side rather than the ASA (static IP) side?
Nitass
sachintyagi Wed, 01/14/2009 - 02:07
Hi Nitass,
Yes the tunnel will always be initiated from the client (Linksys) side.
nitass Wed, 01/14/2009 - 02:18
Hi Sachin,
Sorry I mistyped. Actually, I would like to ask if I can initiate the VPN tunnel from the ASA (static) side or not.
Nitass
Correct Answer
sachintyagi Wed, 01/14/2009 - 03:54
