No Syslogs in Syslog Alert
Jan 14th, 2009
My LMS version is 3.0.1, running on windows system. I can see that my LMS receive syslog from NMSROOT/log/syslog.log, but in syslog alert there is no syslog records found.
In RME>Tools>Syslog>Syslog collector Status I try to unsubscribe then subscribe collector status. Failed on Subscribe collector status.
I go to Common Services > Server > Security > Multi-Server Management > Peer Server Certificate Setup, enter my IP address LMS server, after Importing Peer Certificate windows then Notification window appears (blank window). How to fix my syslog alert?
Joe Clarke Wed, 01/14/2009 - 10:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You do not need to accept your own server's certificate. If you cannot subscribe the Analyzer to the Collector, then one of the two may not be running. Please post the output of the pdshow command as well as the output of netstat -a -n -o -b.
Joe Clarke Thu, 01/15/2009 - 20:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It doesn't appear the SyslogAnalyzer has fully initialized. What version of RME is this?
Joe Clarke Thu, 01/15/2009 - 20:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Nevermind, I see you said LMS 3.0.1. Please post the AnalyzerDebug.log, SyslogAnalyzer.log, and the NMSROOT\MDC\etc\regdaemon.xml.
