01-14-2009 01:18 AM - edited 03-06-2019 03:25 AM
Dear all,
I need to check what ports are in use on my 3550 Version 12.1(14)EA1a .
Could you tell me how to do it pls?
Best regards,
Igor.
Solved! Go to Solution.
01-14-2009 04:15 AM
Hiya,
Basically you have to use two commands.
1)sh int counters ,which will provide data flow info on each interface ,you can clear counters on all ports.If you find any or many with 0, then go on that interface and issue .
2)sh int gigabitEthernet 0/X
and look for
" Last input never, output never, output hang never
Last clearing of "show interface" counters never " or something like that
"Last input never, output 23w2d, output hang never"
This will confirm that, How long that port has been used or not used at all .
Hopes this helps
Nitin
01-14-2009 02:02 AM
You can use the "show interfaces status" command for this. Any port with its status being "up" is being used.
01-14-2009 02:14 AM
Yes I Know, but I need to know if the port is really not in use or if it is not in use in that moment.
01-14-2009 02:27 AM
You may need to check your network design or cableing for this switch.
"Show int status" will provide you the information.
connected > port is connected to device
not connected > ports in use no device connected
Diabled > port is admin down.
If you know which ports are not used you can shut the interface and the status will be shon as disabled
Really not in use are ports with with Disabled status. (If admin down)
Not in use in the movement "not connected"
Hope this helps
01-14-2009 04:15 AM
Hiya,
and look for
Hopes this helps
Nitin
01-14-2009 05:34 AM
The only way to know if its free is as others have said . It would be nice if cisco would put an equivalent of the "show interfaces link" commnad that is used on the cat 4500 series , that tells you exactly when the port was last used but it only works on the 4500's.
