ASA simple routing problem
Answered Question
Jan 14th, 2009
I'm sure, the problem is not a big one, however I'm stuck for now.
I managed to configure an ASA 5505 under home circumstances, with ADSL internet connection. All went smooth, I could rease the internet, and could reach the device from the internet.
The device is deployed now in a server park, with internet connection through a fixed IP and the first hop is a switch of the ISP.
The other side is a small LAN.
I can remotely manage the device, even port forwarding works to LAN, however there is no LAN communication with the WAN. I cannot ping and/or reach anything outside.
I added one static route on the outside, pointing to my ISP switch.
On the LAN I gave the inside leg of the ASA as the default gateway.
Could someone give me some clue where to proceed?
Thank you in advance!
Correct Answer by Pravin Phadte about 7 years 9 months ago
Do u have nat configured ?
if configs provided it would be better to guide you.
Overall Rating: 5 (1 ratings)
Correct Answer
Pravin Phadte Wed, 01/14/2009 - 03:11
janos.csaszar Wed, 01/14/2009 - 03:46
Thank you for your reply!
You should be right.
In the meantime I started to compare the old "working" config and the live one, and realized, that I miss natting.
I will make a try late during the night and will notify.
Thanks again!
Pravin Phadte Wed, 01/14/2009 - 03:49
These are the configs you should be looking at
access-list NoNAT extended permit ip
nat (inside) 0 access-list NoNAT
global (outside) 1 interface
nat (inside) 1
Hope this helps
janos.csaszar Wed, 01/14/2009 - 03:57
I have only the global line, but the working only had the nat line, nothing else.
Do I really need the above 2, you mentioned?
If so, which IP and mask - IP and mask do I need?
Thanks again!
Tshi M Wed, 01/14/2009 - 05:52
Could you please post your ASA configuration? you can alter some information such as public IP addresses and so on.
Pravin Phadte Wed, 01/14/2009 - 05:59
interface Vlan1
nameif inside
security-level 100
ip address
no shutdown
interface Vlan2
nameif outside
security-level 0
ip address
no shutdown
interface Ethernet0/0
switchport access vlan 2
no shutdown
interface Ethernet0/1
switchport access vlan 1
no shutdown
management-access inside
! Default route to the provider
route outside 1
! ASDM access
asdm image disk0:/asdm-611.bin
asdm history enable
! NAT Translation for Internet access
nat (inside) 1
! NAT Exempt configuration
access-list nonat_acl extended permit ip any
nat (inside) 0 access-list nonat_acl
! Specification on what to encrypt
access-list outside_100_cryptomap extended permit ip
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 100 match address outside_100_cryptomap
crypto map outside_map 100 set peer
crypto map outside_map 100 set pfs
crypto map outside_map 100 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
tunnel-group type ipsec-l2l
tunnel-group ipsec-attributes
pre-shared-key testtest
hope this helps
Tshi M Wed, 01/14/2009 - 06:16
the nat(inside)1 should work. Just to narrow this, I would first change the nat (inside)1 to the inside address. Such as
nat (inside)1
Also you might to enable logging so that you can see what is taking placing.
Tshi M Wed, 01/14/2009 - 06:28
yes, it will but you want to find out why the internal LAN is being blocked. I don't see a route inside command in your config so I only can assume that the inside is on the same subnet as the VLAN1 address.
Enable loggin to see why the traffic is being denied. You can use ASDM as well.
Tshi M Wed, 01/14/2009 - 06:35
Hi Pravinxyz,
I totally agree with you. I actually thaught the posting was from the original poster, I didn't realize it was you replying :-)
janos.csaszar Wed, 01/14/2009 - 06:55
It is my pleasure to let you know, that I inserted the single NAT line, and can reach WAN.
Thank you! You saved my day.
Tshi M Thu, 01/15/2009 - 04:51
Good to hear that you are up and running. Which NAT command did you use?
ramnet communic... Wed, 01/14/2009 - 22:04
hi sure,
Iam hari, can u send to me the show tech report of asa 5505, or please add icmp echo-reply commands. then u reach from outside.
