LMS - Status of Crucial Interfaces Reported Immediately
Jan 14th, 2009
Hi Guys
I have a LMS2.6 Bundle , Is it possible that if any critical interface on any device changes its status UP/Down , I should immediately get an email from LMS .
Regards/Asfar
Dear Asfar!
You can use Notification Services in DFM to achieve this task.
Create a EVENT SET First (A,B,C etc)
Create a Notification Group in which u can assign devices for which event set will be applicable.
Than u can Create EMAIL NOTIFICATION based on Notification group.
And it will start sending alerts in email as soon as any event occur.
Asad
asfar.zaidi Wed, 01/14/2009 - 23:34
Dear Asad
Thanks for the reply....can you please elaborate further that how can I add specified critical interface only from particular Devices to the Notification Services of DFM.
Regards/Asfar
