Qos on two routers help
Jan 14th, 2009
Hi all
i have 2 internet routers (2800 series)in to different sites ,and there is a VPN tunnel between them .
The internet line BW for the two sites is
2M . my customer need to dedicate 1M for the VPN traffic between the two sites.
How can i do that on the two routers???
please find the attached files for the routers configuration .
waiting your replies
Joseph W. Doherty Wed, 01/14/2009 - 04:41
You can use CBWFQ to guarantee 1 Mbps for VPN outbound (to the Internet), but unless you control the QoS on the ISP's routers, you won't be able to really effectively guarantee 1 Mbps for VPN inbound (from the Internet).
