NHRP problem (Cisco 881)
Jan 14th, 2009
I want to build a DMVPN with the possibility of creating dynamic tunnels between spokes.
Configuration of the spoke:
interface Tunnel0
description *** MULTIPOINT GRE ***
ip address 10.0.0.40 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication LsP-DMV
ip nhrp map 10.0.0.250 x.x.x.x (//HUB)
ip nhrp map multicast 10.0.0.250
ip nhrp network-id 9999
ip nhrp holdtime 300
ip nhrp nhs 10.0.0.250
ip ospf network broadcast
ip ospf priority 0
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel key 100
tunnel protection ipsec profile DMVPN
when I traceroute another spoke the IPSec tunnel is being created, but the traceroute goes through the Hub.
Result of ip nhrp map on 10.0.0.40:
10.0.0.3/32 via 10.0.0.3
Tunnel0 created 00:02:28, expire 00:01:33
Type: dynamic, Flags: router
NBMA address: x.x.x.x (//HUB)
(Claimed NBMA address: y.y.y.y (//SPOKE))
I believe that it behaves like that because NBMA address is different from Claimed NMBA address. What is interesting that when I traceroute from 10.0.0.3 (where I have 1812 router) it goes directly to 10.0.0.40 (so behaves correctly). So I believe that the problem could be with Cisco 881 (the same configuration among 1812s is working good). Any hints how to run it on 881? Thanks!
Giuseppe Larosa Wed, 01/14/2009 - 09:30
  • Hall of Fame,
    Founding Member
Hello Mariusz,
I remember the first time I tried dynamic spoke to spoke that to trigger the setup of the dynamictunnel I needed to perform
an extended ping using as source the internal LAN and destination a remote LAN spoke
try in this way and then check with
sh crpyto ipsec sa
if you see the new entry to the spoke
as well as a new entry in the sh ip nhrp
Hope to help
Giuseppe
Mariusz Kazmierski Wed, 01/14/2009 - 10:27
Thanks for the message Giuseppe! I am doing an extended ping from the beginning but with no success (i.e. I get !!!!! but the communication goes through the hub, no directly to the second spoke).
Still, a new tunnel between spokes is created correctly (isakmp shows QM_IDLE; ipsec inbound/outbound esp sas: ACTIVE, no packets are encapsulated/decapsulated). About NHRP I get the results presented in my first message.
In 1812 it is working correctly and I believe the problem is probably connected directly with 881(C880DATA-UNIVERSALK9-M). Anyone did such configuration on this platform? Thanks!
Giuseppe Larosa Wed, 01/14/2009 - 11:34
  • Hall of Fame,
    Founding Member
Hello Mariusz,
you mean that if you start the extended ping from the 1812 spoke the dynamic tunnel is used for carrying traffic ?
if so you may consider an IOS upgrade.
I have no direct experience with 881 as a spoke but I had seen limited support on old IOS code on a C7200 that wasn't able to act as NHRP server.
try to see
www.cisco.com/go/fn
Hope to help
Giuseppe
Mariusz Kazmierski Wed, 01/14/2009 - 12:13
Thanks!
I have checked in feature navigator (looking for NHRP) and got a result that my current image (c880data-universalk9-mz.124-20.T1.bin) supports it. Indeed, it correctly works as a spoke in nhrp-hub-spoke topology.
In addition, when I traceroute from spoke-1812 to spoke-881, direct ipsec tunnel between them is used. When I traceroute from spoke-881 to spoke-1812 it goes through the hub. It is kind of weird and I am wondering what can be a issue... maybe 881 does not fully support direct spoke-to-spoke tunnels, maybe additional configuration is needed (sh ip nhrp gives me some suspections but... really don't know what is going on)
