Cisco Secure Desktop clear the browser cache
Jan 14th, 2009
I am looking at Cisco Secure Destkop and in my trials am unable to get it to clear the browser cache on exit.
I.e when I have finished and logged off a session the web address etc is still in my browser history. IE Version 6
I see there is also Cache Cleaner which is supposed to do this but when I select that no difference.
I really like the Secure Desktop but can't find the option to run the secure desktop and have it clear the browser history on exit.
Anyone else have this problem?
Jason Gervia Wed, 01/14/2009 - 06:29
  • Cisco Employee,
What version of ASA and securedesktop are you using?
fashour Thu, 01/21/2010 - 11:14
If multiple Windows Explorer windows are enabled using Windows 2000, Windows Explorer does not erase browser history because other Explorer windows could share it. Before users start Cache Cleaner, they should uncheck "Launch folder windows in a separate process" in the Windows Explorer Tools > Folder Options > View > Launch folder.
