QOS for vpn traffic on two routers
Jan 14th, 2009
Hi all
i have 2 internet routers (2800 series)in to different sites ,and there is a VPN tunnel between them .
The internet line BW for the two sites is
2M . my customer need to dedicate 1M for the VPN traffic between the two sites.
How can i do that on the two routers???
please find the attached files for the routers configuration .
waiting your replies
regards
Mohamed
htarra Tue, 01/20/2009 - 14:53
  • Bronze, 100 points or more
There is no way to specify bandwith on the PIX at all. On the other hand, BECN and FECN are methods for controlling traffic between your router (DTE) and the ISP that provides the frame circuit (DCE). Those are Frame Relay congestion controls, so that, this are specified into a router (since PIX has
only Ethernet interfaces, not serials). In conclusion, the only way to get QoS in the VPN tunnel is with a routing device, not a PIX.
