2 dhcp server in a network
Jan 14th, 2009
I have a 3750 acting as a dhcp server with a range of IP pool and a linksys router with another set of pool. Is there anyway I can configure that certain workstation getting IP from 3750 and certain workstation obtaining from the linksys router?Both are running on different vlan with routing on the 3750.
Overall Rating: 5 (1 ratings)
John Blakley Wed, 01/14/2009 - 07:06
  • Purple, 4500 points or more
Well first, you can have separate DHCP servers as long as they are on:
a) Separate subnets
b) serving different scopes
That in mind, if you have a dhcp scope on your 3750, you would need a vlan interface that is addressed in that same scope:
int vlan 50
ip address 192.168.50.1 255.255.255.0
ip dhcp pool VLAN50
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
dns-server 4.2.2.1
On the OTHER DHCP server that you want to get your addresses from, you would need a separate VLAN interface configured with an IP address like:
int VLAN 100
ip address 192.168.100.1 255.255.255.0
ip helper-address 192.168.100.50
Anything coming in on VLAN 100 will go to the 192.168.100.50 to get an address. You would need a pool for 192.168.100.0 on the DHCP server for that.
I wouldn't recommend using separate DHCP servers though because you can use just the one DHCP server (Linux/Windows) to serve multiple scopes. All VLANs in your switch would have the helper-address assigned as your one DHCP server.
int vlan 50
ip address 10.50.1.1 255.255.255.0
int vlan 225
ip address 172.22.225.1 255.255.255.0
int vlan 322
ip address 192.168.32.1 255.255.255.0
On the DHCP server, you would have:
Scope
10.50.1.0
172.22.225.0
192.168.32.0
You would set all of your options that you need to assign under those scopes.
HTH,
John
