FCC in Africa
Jan 14th, 2009
Hi Team
We have a small problem with the AP's for a University in Africa. The 53 Cisco 1252 Access points that were designed are FCC.
That means on the WiSM I can't change the country code to ZA because the AP then doesn't report in. If I change it to US then the AP's say “RADIO LOW POWER”.
any way to get this right
Thanx in advance
Rob Huffman Wed, 01/14/2009 - 06:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Tau,
This error "Radio Low Power" usually indicates a problem with PoE or power injector config. What are you using for the 1252's?? If you are using an "E" Series 3750 this is a very good thread;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&topicID=.ee6e8b8&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc039db
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
