Configuring Email Alerts in RTMT
Jan 14th, 2009
I have config the email server, alert actions and set the smtp server. Also rebooted the call manager. Please provide some suggestions to help me get the alerts.
Overall Rating: 0 (1 ratings)
Jon Nelson Wed, 01/14/2009 - 08:17
  • Silver, 250 points or more
Check two things:
1. Make sure your UCM server is setup to resolve DNS
2. Make sure you are allowing your UCM server to relay off of your SMTP server
Jon
testeven Wed, 01/14/2009 - 10:16
  • Cisco Employee,
Hi!
You can also try checking that the Exchange server is not blocking the emails for some reason. Sometimes if you have a rule blocking the mails from RTMT_Alert or other email addresses without a fqdn you don't get the alerts.
Check this bug too:
CSCsf08244
RTMT emails do not include domain in from field of SMTP header
Symptom:
Email alerts from RTMT may not be delivered to recipients.
Conditions:
RTMT alerts currently do not supply a domain in the from field of the SMTP header.
Example packet capture of problem:
Simple Mail Transfer Protocol
Command: MAIL FROM:\r\n
Command: MAIL
Request parameter: FROM:
CM logs show:
alertmgr.SendMail - SendMail::send: got address exception=
javax.mail.internet.AddressException: Missing domain in string ``RTMT_Admin@''
Workaround:
assign the fully qualified domain name to the servers involved using the following CLI:
set network dns primary
set network dns secondary
set network domain
Have a nice day!
Teresa.
keenerccna Fri, 01/16/2009 - 08:59
Thanks for the replies i was being blocked by my smtp server.
