01-14-2009 06:49 AM - edited 02-21-2020 03:12 AM
Is there any document on creating custom Endpoint profiles on Cisco NAC Profiler?
(eg. custom printers)
What's the syntax should be?
Sam
01-14-2009 07:13 AM
Have you looked at chapter 9 of the Nac Profiler installation and configuration guide?
http://www.cisco.com/en/US/docs/security/nac/profiler/configuration_guide/218/NACprofiler.pdf
I'm not to familiar with the profiler server but from what i have gathered so far you could view the profiles that the device is currently matching from the "MAC endpoint summary information" and based on that create and finetune you're own custom profile.
01-23-2009 09:13 AM
I have tried all those. The problem is that, it's not profiling properly.
For example, If I have HP Servers and HP printers, and created a profile as generic printers with /printer/i as the search data, all the HP servers are also coming under this profile, which is wrong.
Any clue?
