EIGRP and Floating static issue
pramod
Subnet 10.251.12.64/26 is located at remote location. From central site Core-1 is eigrp neigbhor with 10.90.247.26 (primary path) and secondary internet (VPN tunnel), so from Core-1 we have configured floating static pointing to juniper device. The problem is when primary is down Core-1 is switching to Juniper however when the primary link is back up it does not learn from EIGRP. As soon as I do clear ip route it starts learning thru EIGRP.
When running on secondary path, Core-1 does not even show that subnet learning thru EIGRP.
Core-1#sh ip route 10.251.12.64
Routing entry for 10.251.12.64/26
Known via "static", distance 240, metric 0
Redistributing via eigrp 1
Advertised by eigrp 1
Routing Descriptor Blocks:
* 10.90.247.30
Route metric is 0, traffic share count is 1
Core-1#sh ip eigrp topo 10.251.12.64 255.255.255.192
IP-EIGRP topology entry for 10.251.12.64/26
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 2816
0.0.0.0, from Rstatic, Send flag is 0x0
Composite metric is (2816/0), Route is External
Vector metric:
Minimum bandwidth is 1000000 Kbit
Total delay is 10 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 0
External data:
Originating router is 10.47.158.6 (this system)
AS number of route is 0
External protocol is Static, external metric is 0
Administrator tag is 0 (0x00000000)
Core-1#clear ip route 10.251.12.64 255.255.255.192
Known via "eigrp 1", distance 170, metric 59648
Tag 65011, type external
Advertised by eigrp 1 (self originated)
Last update from 10.90.247.26 on Vlan102, 00:00:04 ago
* 10.90.247.26, from 10.90.247.26, 00:00:04 ago, via Vlan102
Route metric is 59648, traffic share count is 1
Total delay is 110 microseconds, minimum bandwidth is 45045 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 10/255, Hops 1
Core-1>sh ver
IOS (tm) MSFC Software (C6MSFC-DS-M), Version 12.0(7)XE1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Fri 04-Feb-00 00:04 by lstringr
Image text-base: 0x60008900, data-base: 0x60E44000
ROM: System Bootstrap, Version 12.0(3)XE, RELEASE SOFTWARE
BOOTFLASH: MSFC Software (C6MSFC-BOOT-M), Version 12.0(7)XE1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BASRTRNDC006 uptime is 2 years, 45 weeks, 5 days, 20 hours, 42 minutes
System returned to ROM by power-on at 03:38:47 est Thu Sep 8 2005
System restarted at 13:08:03 est Tue Feb 28 2006
Running default software
cisco Cat6k-MSFC (R5000) processor with 122880K/8192K bytes of memory.
Processor board ID SAD04240NKC
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
9 Virtual Ethernet/IEEE 802.3 interface(s)
123K bytes of non-volatile configuration memory.
4096K bytes of packet SRAM memory.
16384K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
Please help how we would resolve this issue, let me know if you need any more information.
Jon Marshall
Pramod
I have just done a quick test of this in a lab and it works for me. Not using 6500 etc. but principle is same with other routers/switches.
Can you post
1) Eigrp config from 6500
2) static routes added on 6500
Jon
John,
Here's the config, the other static routes are also for the same site and has similar issue:
router eigrp 1
redistribute static
passive-interface Vlan1
passive-interface Vlan20
passive-interface Vlan170
network 10.0.0.0
network 138.57.0.0
no auto-summary
ip route 10.85.0.0 255.255.240.0 10.90.247.30 240
ip route 10.251.4.160 255.255.255.240 10.90.247.30 240
ip route 10.251.12.64 255.255.255.192 10.90.247.30 240
Pramod
Ran the following test with "debug eigrp fsm" turned on
Initial State
Using primary path - 192.168.15.2
shutdown interface to 192.168.15.2 so router
then uses static route
ip route 10.251.12.64 255.255.255.192 192.168.15.3 240
SW2#debug eigrp fsm
EIGRP FSM Events/Actions debugging is on
SW2#
01:10:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/10, chan
ged state to down
01:10:21: %LINK-3-UPDOWN: Interface FastEthernet0/10, changed state to down
01:10:30: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 192.168.15.2 (Vlan102) is d
own: holding time expired
01:10:30: DUAL: linkdown: start - 192.168.15.2 via Vlan102
01:10:30: DUAL: Destination 192.168.15.0/24
01:10:30: DUAL: Destination 10.251.12.64/26
01:10:30: DUAL: Find FS for dest 10.251.12.64/26. FD is 2816, RD is 2816
01:10:30: DUAL: 192.168.15.2 metric 4294967295/4294967295 not found Dmin
is 4294967295
01:10:30: DUAL: Peer total/stub 0/0 template/full-stub 0/0
01:10:30: DUAL: Dest 10.251.12.64/26 (No peers) not entering active state.
01:10:30: DUAL: Removing dest 10.251.12.64/26, nexthop 192.168.15.2
01:10:30: DUAL: No routes. Flushing dest 10.251.12.64/26
01:10:30: DUAL: linkdown: finish
01:10:30: DUAL: dest(10.251.12.64/26) not active
01:10:30: DUAL: rcvupdate: 10.251.12.64/26 via Rstatic metric 2816/0
01:10:30: DUAL: Find FS for dest 10.251.12.64/26. FD is 4294967295, RD is 429496
7295 found
01:10:30: DUAL: RT installed 10.251.12.64/26 via 192.168.15.3
01:10:30: DUAL: Send update about 10.251.12.64/26. Reason: metric chg
01:10:30: DUAL: Send update about 10.251.12.64/26. Reason: new if
Bring interface to 192.168.15.2 back up
router replaces static route with route
received from 192.168.15.2
SW2#sh debug
EIGRP:
SW2#
01:11:57: %LINK-3-UPDOWN: Interface FastEthernet0/10, changed state to up
01:11:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/10, changed state to up
sh debug
01:12:32: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 192.168.15.2 (Vlan102) is up: new adjacenc
y
01:12:34: DUAL: dest(10.251.12.64/26) not active
01:12:34: DUAL: rcvupdate: 10.251.12.64/26 via 192.168.15.2 metric 2816/256
01:12:34: DUAL: Find FS for dest 10.251.12.64/26. FD is 2816, RD is 2816
01:12:34: DUAL: 192.168.15.3 metric 2816/0
01:12:34: DUAL: 192.168.15.2 metric 2816/256 found Dmin is 2816
01:12:34: DUAL: RT installed 10.251.12.64/26 via 192.168.15.2
01:12:34: DUAL: Send update about 10.251.12.64/26. Reason: new if
01:12:34: DUAL: rcvupdate: 10.251.12.64/26 via Redistributed metric 4294967295/4294967295
01:12:34: DUAL: 192.168.15.3 metric 4294967295/4294967295 found Dmin is 2816
01:12:34: DUAL: Removing dest 10.251.12.64/26, nexthop 192.168.15.3
As you can see it all works fine for me. Perhaps you could run this debug out of hours to see what you get ?
Jon
