Looking to update 7500 RSP4 due to memory utilization, RSP 8 vs 16
Trying to decide whether the RSP8 or RSP16 is a good upgrade path for us from a RSP4.
Right now I have two 7500's, one with the RSP4 and one with the RSP8. I'm deciding whether to just update one of them to a RSP8, or upgrade both to RSP16's.
My issue is current memory utilization on the RSP4.
The DRAM specs look the same between the RSP4 and RSP8. I realize the pps are much higher on the RSP8 but I can't find any info on whether this increase will result in less memory used.
Any help is appreciated.
