Hub to spoke ipsec vpn
Jan 14th, 2009
We've 7206 vxr router with atm oc-3 interface.Our branches are connected the hub site via p2p ATM port,we have no encryption on the links and we want to migrate this links to ipsec vpn tunnels and hub&spoke topology.
What is the best solution for this issue
Giuseppe Larosa Wed, 01/14/2009 - 09:35
  • Hall of Fame,
    Founding Member
Hello Tolga,
if all your routers are Cisco you should think to use DMVPN
see
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/DMVPDG.html
you can also implement QoS over DMVPN.
But you want to implement encryption over the ATM links or to leave the ATM links and to use internet accesses ?
In both cases you should be able to use DMVPN.
Hope to help
Giuseppe
tdorduncu Thu, 01/15/2009 - 07:54
we've p2p ATM links,we can not leave this.Any solution for this infstracture ?
Rick Morris Thu, 01/15/2009 - 09:49
  • Silver, 250 points or more
Why do you need encryption on a p2p link running ATM? In theory you are only extending your LAN.
tdorduncu Thu, 01/15/2009 - 23:37
ATM link its pass through over ISP links,we have to encrypt data on this links
