Routing Problems With Bgp And Eigrp Cisco 3825
Answered Question
Jan 14th, 2009
Hello everybody, I have a problem routing and i dont know where find the THE SOLUTION.
I have two ROUTERS connected by MICROWAVE, ROUTER A AND ROUTER B the router A is making BORDER WITH A ISP, I also have my own system SELF-DECLARED 42384.ROUTER A SET UP BGP4 (TO ISP) and EIGRP (TO MY COMPANY)MY PROBLEM IS:
1. ROUTER B NO PINGING TO EXTERIOR NETWORK, BUT IF PINGING TO ALL INTERFACE OF ROUTER A
2. THE ROUTER A PINGING TO EXTERIOR NETWORK AND INTERIOR NETWORK
Please can you help me ?? I'm desperate
Thanks a lot
I paste the output routers onfigurations
*****************************************ROUTER A
interface GigabitEthernet0/0
description ISP
bandwidth 200000
ip address 184.224.29.214 255.255.255.252
duplex auto
speed auto
media-type sfp
interface GigabitEthernet0/1
ip address 194.201.212.10 255.255.255.252
ip authentication mode eigrp 42384 md5
ip authentication key-chain eigrp 42384 CCC
duplex auto
speed auto
router eigrp 42384
passive-interface GigabitEthernet0/0
network 194.201.212.8 0.0.0.3
no auto-summary
router bgp 42384
no synchronization
bgp log-neighbor-changes
network 184.224.29.212
redistribute connected
neighbor 184.224.29.213 remote-as 9376
neighbor 184.224.29.213 description conexion con cz1
neighbor 184.224.29.213 password 7 55547010A66607298757C
neighbor 184.224.29.213 version 4
neighbor 184.224.29.213 prefix-list CCC-OUT out
no auto-summary
ip classless
ip prefix-list CCC-OUT description Prefijos anunciados por CCC
ip prefix-list CCC-OUT seq 5 permit 194.201.212.0/20
ROUTER B
description CCC TO IBEROSTAR MICROWAVE
ip address 194.201.212.9 255.255.255.252
ip route-cache flow
duplex full
speed 1000
no ip address
duplex full
speed 1000
interface GigabitEthernet0/1.112
description BACKBONE
encapsulation dot1Q 212
ip address 194.201.212.18 255.255.255.240
interface GigabitEthernet0/1.114
description CORPORATE NETWORK
encapsulation dot1Q 214
ip address 194.201.214.1 255.255.254.0
router eigrp 42384
passive-interface GigabitEthernet0/1.1
network 194.201.212.16 0.0.0.15
network 194.201.214.0 0.0.1.255
no auto-summary
SHOW IP ROUTE IN ROUTER B
Gateway of last resort is 194.201.212.10 to network 0.0.0.0
10.0.0.0/24 is subnetted, 1 subnets
C 10.154.30.0 is directly connected, GigabitEthernet0/1.1
194.0.0.0/8 is variably subnetted, 6 subnets, 3 masks
C 194.201.212.8/30 is directly connected, GigabitEthernet0/0
C 194.201.214.0/23 is directly connected, GigabitEthernet0/1.114
C 194.201.212.16/28 is directly connected, GigabitEthernet0/1.112
S* 0.0.0.0/0 [1/0] via 194.201.212.10
SHOW IP ROUTE IN ROUTER A
Gateway of last resort is 184.224.29.213 to network 0.0.0.0
184.0.0.0/30 is subnetted, 1 subnets
C 184.224.29.112 is directly connected, GigabitEthernet0/0
C 194.201.212.8 /30 is directly connected, GigabitEthernet0/1
D 194.201.212.0/23
[90/3072] via 194.201.212.9, 01:08:12, GigabitEthernet0/1
D 194.201.212.16/28
[90/3072] via 194.201.212.9, 01:08:14, GigabitEthernet0/1
B* 0.0.0.0/0 [20/0] via 184.224.29.213, 02:12:39
Correct Answer by Giuseppe Larosa about 8 years 5 months ago
Hello Alejandro,
nice to hear that you have solved.
However, as Kelvin as pointed out you may need to generate a default route in EIGRP on RouterA to be able to route from inside your network.
the static route on RB is fine for RB, but if there are other routers more internal they need to receive a default route in EIGRP.
About the policies and prefix-lists you should be fine: they are used as safety measures for example to avoid to advertise somebody's else IP address block.
Hope to help
Giuseppe
Overall Rating: 5 (3 ratings)
Giuseppe Larosa Wed, 01/14/2009 - 09:11
  • Hall of Fame,
    Founding Member
Hello Alejandro,
on your BGP router RA you would like to advertise your public address ip block as specified by prefix-list CCC-out but there is nothing that allow to advertise that /20 prefix
you can check this with
sh ip bgp
sh ip bgp neigh 184.224.29.213 advertised-routes
you need under router bgp
or to redistribute eigrp into BGP
router bgp 42834
redistribute eigrp 42834
or to add network commands within 192.201.212.0/20
AND also
aggregate-address 194.201.212.0 255.255.240.0
to create the correct aggregate
Hope to help
Giuseppe
agrindley Wed, 01/14/2009 - 10:22
Many thaks Giuseppe ,
Im redistributing eigrp into BGP but the problem continues I can not pinging from the router B to exterio network
show the output of ip bgp neig
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>0.0.0.0 184.224.29.213 0 6739 i
*>184.224.29.212/30 0.0.0.0 0 32768 ?
*>194.201.212.8/30 0.0.0.0 0 32768 ?
*>194.201.212.16/28 194.201.212.9 072 32768 ?
*>194.201.214.0/23 194.201.212.9 3072 32768 ?
I appreciate your help
Giuseppe Larosa Wed, 01/14/2009 - 11:37
  • Hall of Fame,
    Founding Member
Hello Alejandro,
have you also added the aggregate-address ?
I don't see it in the sh ip bgp and so if the prefix-list is applied still nothing is advertised to the provider (only /20 is allowed )
Hope to help
Giuseppe
kwillacey Wed, 01/14/2009 - 12:18
  • Bronze, 100 points or more
I'm not sure maybe I read what you have above wrong but it seems to me like routerA goes out to the Internet and routerB is behind routerA.
In that case bgp needs to be redistributed into EIGRP on routerA in order for routerB to get to the networks in front of routerA and based on the routing table of routerB it has none of the BGP learnt routes via EIGRP (DEX).
Giuseppe Larosa Wed, 01/14/2009 - 12:41
  • Hall of Fame,
    Founding Member
Hello Kelvin,
what you say is important
there is a static default route (or there was)
but this is something that has to be considered up to now we have focused on the return path.
Hope to help
Giuseppe
agrindley Thu, 01/15/2009 - 01:44
Hello Giuseppe perfect. you are great
Many thanks another time, your solutions its correct and the trafic it s working fine.
I think my provider had no knowledge of how I was trying the network.I am a newbie with these routing and I have many doubts
I am not very clear if I need to use prefix-list, routing policies, so I accept all kinds of tips
something else to keep in mind to the network
cheers
agrindley Thu, 01/15/2009 - 01:47
thanks to all who make this forum (giuseppe, kelvin, CISCO, etc etc)
Correct Answer
Giuseppe Larosa Thu, 01/15/2009 - 01:57
  • Hall of Fame,
    Founding Member
Hello Alejandro,
Hope to help
Giuseppe
