LMS 2.6 RME 4.0.5 : Unable to subscribe to SyslogCollector error SLCA0126
ogor
In RME+Tool+Syslog, I can't arrive to subscribe to the "Syslog Collector"
SLCA0126: Could not subscribe to the Collector.
1.Check whether the collector is running.
2.Make sure that SSL certificates are imported/exported correctly and process restarted.
3.Check whether the Certificates exported/imported are valid and have not expired.
4.Check whether SyslogAnalyzer process is running.
but my syslog are correctly collected to the "syslog.log" file located in CSCOpx\log directory.
The SyslogCollector and SyslogAnalyzer are running correctly
D:\LMS>pdshow SyslogAnalyzer
Process= SyslogAnalyzer
State = Program started - No mgt msgs received
Pid = 4632
RC = 0
Signo = 0
Start = 1/14/2009 7:30:19 PM
Stop = Not applicable
Core = Not applicable
Info = Server started by admin request
D:\LMS>pdshow SyslogCollector
Process= SyslogCollector
Pid = 11928
RC = 0
Signo = 0
Start = 1/14/2009 7:26:00 PM
I'm in US regional setting and the TCP 4444 is not used (as shown by the netstat -an in attached file)
And see my Collector.properties is in attached file
Many thanks in advance for your help
Olivier
Please post the new pdshow output as well as the output of netstat -a -n -o -b.
11 Replies 11
ogor
Please also find attached the SyslogCollector.log and SyslogAnalyzer.log
and the complete pdshow and analyzerdebug.log
Thanks ;)
This is most likely bug CSCsh66475. It is fixed in RME 4.0.6 which can be downloaded via Common Services > Software Center > Software Update.
My server is not connected to the internet for security reasons, in case of, have you got the link of this update please ?
thanks
Olivier
I have downloaded the RME 4.0.6 service pack but a prerequisite of this update is to install the CS4.0.6 service pack but it no longer available on the cisco web site ?
Do you have the patch anywhere please ?
Olivier
Those are the correct links. If you also have Campus Manager or DFM installed, they will need to be upgraded as well. See http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-campus and http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-dfm respectively. The latest version of Campus is 4.0.12, and the latest version of DFM is 2.0.12.
I have updated the RME and CS but the pb is still the same.
The new behavior is that I arrived to subscribe to the certificate in CS, Server, Security and Peer Server Certificate Setup
before the RME 4.0.6 and CS3.0.6 it was not possible.
But also, the subscribing in RME, Tools, syslog is not possible the error SLCA0126 still remain.
Here is an error in SysloganalyzerUI.log
[ Fri Jan 16 11:38:10 WAT 2009 ],ERROR,[Ajp13Processor[9009][3]],SA0015: Cannot contact SyslogAnalyzer service for updating Collector status information
com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "SyslogAnalyzerService" : Not found !!
Please find attached the log requested.
thanks in advance.
Olivier
I saw the pdshow and the TCP 4444 is used by omnivision software so I will remove it and after it will be better ;) I hope
Olivier
