Cisco Messaging Interface - Service Status DOWN
Answered Question
Jan 14th, 2009
We upgraded from CM 4.2 to 7.0(1). Everything looks like it's working okay except we're getting Cristical Service Down messages in RTMT - Service Status is down, Cisco Messaging Interface. Alerts are popping up almost every minute. Any ideas where to start looking?
Correct Answer by Jaime Valencia about 8 years 2 months ago
legacy meaning an SMDI integration. Unity is SCCP or SIP, doesn't need at all the CMI service
java
if this helps, please rate
Overall Rating: 4 (1 ratings)
Jaime Valencia Wed, 01/14/2009 - 12:05
  • Cisco Employee,
  • Hall of Fame,
    2011
are you using a legacy VM integration???
if not, then there's nothing to worry about as that service if for that purpose
java
f.kirstein Wed, 01/14/2009 - 12:10
As long as Unity isn't considered a legacy VM app. Can I disable this service?
Thank you.
Correct Answer
Jaime Valencia Wed, 01/14/2009 - 12:11
  • Cisco Employee,
  • Hall of Fame,
    2011
java
