WIC-4ESW as WAN
Answered Question
Jan 14th, 2009
I currently have a 1751 acting as our main gateway. At the moment it has two WIC-T1 cards, multi-interfaced.
Now, we're doing away with our 2xT1 for a 10MB fiber link. The fiber will be terminated and delivered to our equipment via the standard RJ-45. So, that's why I'm looking to get the WIC-4ESW since I'll need another port on our 1751 to terminate the connection to the fiber.
I've never used a WIC-4ESW, or anything of the sort to add more Ethernet ports to a router. My intentions are to use one of the four ports on this card as the link to our WAN. So, it'll have a private IP assigned to it. Even though it's an addon module, I can still assign an IP address to each port on it right?
Second question, I read a few posts online, and that beings this card is a layer 3 device, that I can't expect it to run at a 10MB level even though it's a 10/100MB link because of the routers processor. Is this correct? Should I be looking at something else instead of this four port card for terminating a high-speed WAN connection?
Correct Answer by Joseph W. Doherty about 8 years 4 months ago
He might have gotten it from this reference.
Correct Answer by Collin Clark about 8 years 4 months ago
The 1751's max throughput is 6.14Mbps (CEF), so you'll probably want to look at a larger router. The 1800 series should work well in your case. If you add an HWIC-4ESW, the ports are strictly layer 2 ports! You create VLANs in the router and assign the port to the VLAN. You now have another interface albeit virtual.
Hope that helps.
Overall Rating: 5 (2 ratings)
Correct Answer
Collin Clark Wed, 01/14/2009 - 14:01
  • Purple, 4500 points or more
Hope that helps.
kwillacey Thu, 01/15/2009 - 05:59
  • Bronze, 100 points or more
Did not even now that was available, it will definitely save time looking through data sheets, thanks.
