MPLS TE Tunnels configuration
Answered Question
Jan 14th, 2009
Hello.
I have the following doubt. What happens if I configure one TE tunnel in both ends. I have read that is enough configure only one side.
Correct Answer by gauravprakash about 8 years 4 months ago
The LSP starts on PE on which Tunnel was built and ends on some ther PE, and its unidirectional. To have bidirectional you need to make two Tunnels on each end.
HTH,
Gaurav Prakash
Overall Rating: 5 (1 ratings)
Correct Answer
gauravprakash Thu, 01/15/2009 - 06:40
HTH,
Gaurav Prakash
