Erlang - does no of lines mean the same as channels on ISDN
Jan 14th, 2009
For example if the Erlang calculater works out that I need 19 lines. Is this the same as 19 voice channels on a T1 or E1 PRI ?
Overall Rating: 3 (1 ratings)
david.macias Wed, 01/14/2009 - 14:01
  • Blue, 1500 points or more
If that's all the information you have, then yes I would assume that 19 lines means 19 voice channels or the ability to have 19 concurrent calls at once.
david
