Using FIber connections on Catalyst 2960
Jan 14th, 2009
I have a Catalyst 2960 and when I try to connect fiber to it it does not connect. It works fine with the ethernet connection in the same port. Is there anything special I need to do to make that work?
Here is the configuration for that port:
interface GigabitEthernet0/1
switchport trunk allowed vlan 1,100
switchport mode trunk
macro description cisco-switch
jlauner99 Thu, 01/15/2009 - 13:56
It is recognizing the media but will not communicate over it. No link lights are on either switch. It works fine on ethernet.
Sushil Kumar Katre Fri, 01/16/2009 - 03:35
Hi Jesse,
Let us know which SPF module are you using.
Please make sure if its 1000Base SX then you are using a Multi Mode Fiber cable and not Single Mode.
Also make sure that you have similar SFPs on both the sides.
-> Sushil
jlauner99 Fri, 01/16/2009 - 06:16
It is a multimode fiber cable with gender changers in the middle because one end of the cable is SC and the other is LC. The GBIC are GLC-SX-MM from Cisco and it is 1000Base SX
