IPCC export config tool
Answered Question
Jan 14th, 2009
  • Gold, 750 points or more
I have to migrate IPCC Express 4.0 configuration to a new UCCX 5.0. What can I use to export config and import in 5.0?
- Adrián.
Correct Answer by Jonathan Schulenberg about 8 years 4 months ago
There is a migration tool for the historical reporting data only. Everything else must be done manually.
UCCX HR-DataMigration Guide 4.0.5x to 7.0.1: http://www.cisco.com/web/software/282467017/23664/UCCX_HR-DataMigration_Guide_4.0.5x_to_7.0.1.pdf
Correct Answer by slavr about 8 years 4 months ago
Hello Adrán.
There is no upgrade path from 4.0(x) -> 5.0(x)
You have to manually copy Documents, Prompts and Scripts from 4.0 server and manually upload them to the 5.0 server.
You can zip your files with a limit of 20Mb in each zipfile.
Then you manually have to create applications and config of all subsystems.
Good luck.
\Soren Lavard
Overall Rating: 5 (2 ratings)
Correct Answer
slavr Wed, 01/14/2009 - 15:22
Hello Adrán.
Good luck.
\Soren Lavard
Adrian Saavedra Wed, 01/14/2009 - 15:58
Hi Soren,
Thanks for your response.
Best regards,
- Adrián.
Adrian Saavedra Wed, 01/14/2009 - 18:38
Hi Jonathan,
Thanks for the tip :)
So, I'll backup historical reporting with the tool and everything else manually.
- Adrián.
